Come correggere le icone Font Awesome
I just use a mixin
@mixin fAwesome ($fa, $col) {
    &.bullet::before {
        color: $col;
    &.bullet::before {
        content: $fa;
.tag-official { @include fAwesome("\f135", #A2C785); }); }}
to add icons for my tags.
Everything works fine, but the icon does not display in the nav, only an empty square
Icon:
Снимок экрана (553)
The font for .bullet::before is not set to FontAwesome,
You need to add the equivalent of this to your mixin:
.bullet::before {
     content: "";
     color: black;
     font: normal normal normal 14px/1 FontAwesome;
thanks for your reply. I had another question. Now the icon display outside the frame. How do I put it inside?
Снимок экрана (556)
I want to do something like this
Снимок экрана (557)
Instead of using .tag-official try using a.tag-official to only apply the styles to links inside the list and not on list items if they also share the class.
^ this also includes adding margin-right: 5px
