abcoathup
(Andrew B Coathup)
15.Май.2019 07:00:00
I am using a hosted Discourse service and wanted to know how to get Solidity syntax highlighting working.
Solidity isn’t a language in GitHub - highlightjs/highlight.js: JavaScript syntax highlighter with language auto-detection and zero dependencies. · GitHub but there is a repo for the Solidity language GitHub - highlightjs/highlightjs-solidity · GitHub .
sam
(Sam Saffron)
15.Май.2019 07:03:16
Best approach is to submit a PR to highlightjs to add it, that way we will get it next time we upgrade highlightjs
abcoathup
(Andrew B Coathup)
15.Май.2019 07:56:41
What is the frequency of that?
sam
(Sam Saffron)
15.Май.2019 07:57:50
We pretty much update every release, if you get it into highlight we will update.
abcoathup
(Andrew B Coathup)
11.Июнь.2019 06:12:31
Hi @sam
I have been advised that Solidity should stay in it’s own repo (GitHub - highlightjs/highlightjs-solidity · GitHub ) rather than be added to the highlight.js repo.
https://github.com/highlightjs/highlight.js/pull/2051#issuecomment-499711780
How do I configure a hosted discourse forum to use this repo?
sam
(Sam Saffron)
11.Июнь.2019 07:08:00
I added a comment there, will follow up next week here depending on the response we get.
Perhaps create your own repo with the language, to start? We can then add it to the list of highlight languages we pull?
abcoathup
(Andrew B Coathup)
11.Июнь.2019 08:57:30
7
Hi @sam
A repo with the Solidity language is in the highlightjs organisation already:
https://github.com/highlightjs/highlightjs-solidity/
abcoathup
(Andrew B Coathup)
25.Июнь.2019 01:11:37
9
Hi @sam did you get any response?
sam
(Sam Saffron)
25.Июнь.2019 01:15:03
10
Nothing from GitHub… not sure what we are meant to do here.
abcoathup
(Andrew B Coathup)
25.Июнь.2019 01:17:54
11
My goal is syntax highlighting of the Solidity language in a hosted Discourse forum.
Just trying to work out how to get there
sam
(Sam Saffron)
25.Июнь.2019 01:21:24
12
I am assigning this out, we will figure something out, give us a couple of weeks.
pmusaraj
(Penar Musaraj)
26.Июнь.2019 02:54:48
15
Hi @abcoathup ,
Please try this theme component: GitHub - pmusaraj/discourse-highlight.js-solidity · GitHub
I had to build Highlight.JS with the solidity language and then use the generated minimized language in Discourse. Step-by-step details in the component’s readme.
abcoathup
(Andrew B Coathup)
27.Июнь.2019 06:02:09
16
Hi @pmusaraj and @sam
We are on a hosted Business plan, so assume that I can’t add this plugin.
What other options do we have to get Solidity syntax highlighting?
This isn’t a plugin, it’s a theme component that you can add to an existing theme. You are free to install themes and theme-components by yourself using these instructions: Installing a theme or theme component
abcoathup
(Andrew B Coathup)
27.Июнь.2019 07:16:16
18
Awesome, we now have Solidity syntax highlighting in Discourse.
