in admin panel, i can modify user title as any string.
but in user panel, they only can use pre-defined Badge as title.
what can i do if i want to open custom title to users ?
There is no way to do this. Some sites treat âfull nameâ as a title and change it all the time to âfunnyâ values.
@codinghorror: Is there a particular reason for this? Could there be a site setting to enable arbitrary titles for users, so real names can remain, well, real?
As an admin you can modify title for your users if you want. But you have to do it manually for each user.
I use this option only for super-devoted users.
Just a friendly warning to @zh99998 before encouraging users to change it: the âfull nameâ field is also used for email notifications so you might get emails from e.g. âthe popeâ.
Only if you set email to use real name. You can just as easily have username appear in the from: field via a simple site setting.
I like it, possibility to customize the title could be a good award
Thatâs generally what we do as well. The admins all have âTeam Radientâ as their title, and the mods have support something or other as theirs. We then give our very devoted users or those who have done something above and beyond an honorary title. We have titles like âMaster Translatorâ, âStonehearth Architectâ, and âStonehearth Scribeâ.
There is a partial solution this⊠you can let them pick from a list of pre-approved Titles.
Make Badges which have the checkbox âcan be used as titleâ and then your users can pick from the badges they have earned.
I also think this could be a great feature in the future. It could even be linked to a specific user profile field. In our case we would love the title to be used for job title - since our discourse is for people in the design industry and it would be great to show what their job titles are and where they work
This is already possible with badges, if the badge confers a title, it is available to the user.
On other sites, simply displaying full names (see how yours says âCommon mc commonpawnâ) gives users a de-facto âtitleâ they can edit as they see fit by editing their full name. A number of sites do this and engage in this practice of wacky full names.
Yes, but we canât create a badge for every job title out there
e.g. âFront-end dev @ Discourseâ âUX Designer @ Googleâ, etc.
Weâre currently thinking about solving it by changing the name of the full name field to job title - however, we would also love to keep the full name field reserved for full names ![]()
Custom User Field + plugin to change post template (widget now) + some css would be needed for that.
As it stands, custom titles serve a role as staff-vetted strings to put next to your name - users canât falsify them (but they can remove them, usually).
The âfull nameâ does well for having fun ![]()
