Let's Encrypt وموقع متعدد (على حاويتين)
Continuing the discussion from Setting up Let’s Encrypt with Multiple Domains:
Hi!
I tried this how to but nothing changed and /etc/runit/1.d/letsencrypt is not modified.
I’ve 2 containers (data.yml) and web.yml and want to use multisite config.
Here the after_ssl I used (from Set up Let’s Encrypt with multiple domains / redirects - #15):
after_ssl:
    - replace:
        filename: "/etc/runit/1.d/letsencrypt"
        to: |
          -d forum.test.com -d forum2.test.com -d forum-test.test.com -k 4096 -w /var/www/discourse/public
    - replace:
        from: /-k 4096 --force -w \/var\/www\/discourse\/public/
        to: |
          -d forum.test.com -d forum2.test.com -d forum-test.test.com -k 4096 --force -w /var/www/discourse/public
The only discourse the default one (DISCOURSE_HOSTNAME).
For the other one, I get the following error when I do a curl:
curl: (51) SSL: no alternative certificate subject name matches target host name 'forum-test.test.com'
Which yml did you add the after_ssl to?
Also, one of those links about let’s encrypt describes how to inspect the logs of the script, perhaps some in there will help diagnose.
I added it to web_only.yml
web.yml or web_only.yml?
What is the launcher command you are using when doing the rebuild?
I renamed it web_pe.yml. So I’m using ./launcher rebuild web_pe
I can’t see any recent changes that would stop the regex in the from working but obviously something is not right. Is there anything unusual in the templates: of your web_pe.yml that could be altering the base ssl before the after_ssl happens?
No, here is the templates: of my web_pe.yml:
templates:
  - "templates/web.ratelimited.template.yml"
## Uncomment these two lines if you wish to add Lets Encrypt (https)
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
Here is the after_ssl hook I have in web_pe.yml:
after_ssl:
    - replace:
        to: |
          -d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 -w /var/www/discourse/public
    - replace:
        to: |
          -d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 --force -w /var/www/discourse/public
Here are the logs during the bootstrap:
I, [2018-08-20T01:52:07.061735 #13]  INFO -- : Replacing (?-mix:-k 4096 -w \/var\/www\/discourse\/public) with -d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 -w /var/www/discourse/public
 in /etc/runit/1.d/letsencrypt
I, [2018-08-20T01:52:07.062730 #13]  INFO -- : Replacing (?-mix:-k 4096 --force -w \/var\/www\/discourse\/public) with -d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 --force -w /var/www/discourse/public
Here is the etc/nginx/letsencrypt.conf
LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue -d forum.pragmaticentrepreneurs.com -k 4096 -w /var/www/discourse/public
if [ ! "$(cd /shared/letsencrypt/forum.pragmaticentrepreneurs.com && openssl verify -CAfile ca.cer fullchain.cer | grep "OK")" ]; then
  # Try to issue the cert again if something goes wrong
  LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue -d forum.pragmaticentrepreneurs.com -k 4096 --force -w /var/www/discourse/public
fi
LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --installcert -d forum.pragmaticentrepreneurs.com --fullchainpath /shared/ssl/forum.pragmaticentrepreneurs.com.cer --keypath /shared/ssl/forum.pragmaticentrepreneurs.com.key --reloadcmd "sv reload nginx"
The last line should be modified, shouldn’t be?
No, the file that gets modified in the container is /etc/runit/1.d/letsencrypt.
Ok! So here is the /etc/runit/1.d/letsencrypt file of my web container:
# cat /etc/runit/1.d/letsencrypt
#!/bin/bash
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf
fi
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf -s stop
Yeah, not sure what’s going on there. Sorry!
Which indicate it attempts the replace but since it didn’t happen then it must have failed? I don’t know if there is any other diagnostic that can be used to determine success of fail of a pups replacement.
All I can think of is either the replace is not working or you are somehow entering the wrong container? Kind of weird, it all looks ok to me.
That’s weird. To be sure, I just need to run ./launcher bootstrap web_pe, right ?
What command do you use to enter the container where you ran the cat /etc/runit/1.d/letsencrypt ?
I’m running the following:
$ cd /var/discourse/
$ ./launcher enter web_pe
$ cat /etc/runit/1.d/letsencrypt
Am I wrong?
PS: Here is what I get when I run docker ps
CONTAINER ID        IMAGE               COMMAND             CREATED             STATUS              PORTS                                      NAMES
b3d5c1de8bae        7660254ef762        "/sbin/boot"        5 weeks ago         Up 13 hours         0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp   web_pe
4f929aed8712        e4dabeee27af        "/sbin/boot"        6 weeks ago         Up 13 hours                                                    data
I cannot see anything that looks wrong!
Ho I found out! Thank you very much for your help.
I needed to run ./launcher rebuild instead of ./launcher bootstrap
