Links containing underscores don't get oneboxed
I noticed that links containing underscores (_) don’t get oneboxed correctly under certain conditions, because the underscores get interpreted as formatting directives.
Consider this link:
https://github.com/arve0/fijibin/blob/a3d2e983cb9ff2bcbb56a800084bc3b35cb9292f/fijibin/__init__.py#L23
Trying to onebox:
This can be worked around using %5F to replace the first underscore:
https://github.com/arve0/fijibin/blob/a3d2e983cb9ff2bcbb56a800084bc3b35cb9292f/fijibin/%5F_init__.py#L23
simply put brackets around it like so
<https://github.com/arve0/fijibin/blob/a3d2e983cb9ff2bcbb56a800084bc3b35cb9292f/fijibin/__init__.py#L23>
Not a bug, auto linking cannot be expected to work in all scenarios. See http://commonmark.org/help for the markdown spec on this
That doesn’t get oneboxed, either (the percent encoding method seems like the right way to work around this).
I agree with @notriddle: adding the brackets (<>) will keep the link intact, but actually prevents oneboxing in my trials.
I am half open to allowing oneboxing (but not mini oneboxing) it is quite an edge case though. The bug is in linkify: GitHub - markdown-it/linkify-it: Links recognition library with full unicode support · GitHub so may be worth mentioning in an issue there.
