Logging checked_for_custom_avatar
I just exported all my logs, and found something interesting.
checked_for_custom_avatar accounted for 42,525 lines,
check_email accounted for 364 (maybe that gets purged?)
the other 880 items were all quite varied.
I wonder if we could skip logging checked_for_custom_avatar ?
「いいね!」 4
Whew! sounds like it could use it’s own log file.
Yes, this seems absurd, can we remove logging this @zogstrip?
I checked into this, and this is a per-user history entry that verifies we looked up their avatar.
context "a user who has been checked for a custom avatar" do
      before do
        UserHistory.create!(action: UserHistory.actions[:checked_for_custom_avatar], target_user_id: user.id )
      end
    # Finally, we don't check users whose avatars haven't been examined
    return unless UserHistory.exists_for_user?(@user, :checked_for_custom_avatar)
Which logs are you referring to? How are you exporting the per-user history logs? These are not under admin/logs AFAIK.
Also do you have 45,525 users? There should only be one of these records per user.
I was at [our forum]/admin/logs/staff_action_logs
I clicked the Export, and a while later received a notice that the export was ready.
We have about 500 users total.
I just did it again, same 2.4mb file, some 43785 lines.
I see that they mostly stopped in June of 2014… so maybe this was an old bug?
I wonder if there’s a reasonable way to purge all those?
Let me export our staff logs and get back to you.
edit: confirmed, we have a zillion of these rows as well in Staff Action Logs. That stopped about 5-27-2014. Looks like some kind of bug in the export process and/or an issue with the number of those records in the individual user histories. @techapj is having a look.
Fixed:
https://github.com/discourse/discourse/pull/3074
That’s because that entry is not used anymore and has been removed in
https://github.com/discourse/discourse/commit/6c1c8be79433f87bef9d768da7b8fa4ec9bb18d7
I pushed a database migration to remove these useless user history entries
https://github.com/discourse/discourse/commit/c57a1b393f0fefb9e3094514fa03c9c5046cc6f9
