Making filters work without reload
I’ve just done some work on discourse-solved, and added some filters. These work fine if you visit the URLs directly, but if you follow a link from within the site then it doesn’t work.
If I click on this link, it doesn’t apply the filter until I hit reload.
Support - Discourse Meta
Do I need to add it to the Ember router or something like that? How would I go about doing that?
AddDiscoveryQueryParam is your friend
https://github.com/discourse/discourse-assign/blob/master/assets/javascripts/discourse/initializers/extend-for-assigns.js.es6#L59
Well, that was easy - it’s almost like someone’s had this problem before :wink:
Thanks again, I’ve submitted another PR
Just in case someone comes across this thread in future, using “true”/“false” in the query variables can create some unexpected behaviour. Ember will consider “false” the default, which might not be what you want.
Isso está funcionando?
Notei que quando seleciono o filtro solved, ele não filtra os tópicos, a menos que eu recarregue a página.
