Hi there,
I’m supporting a customer with Discourse and i’ve been asked to help them with private topics but visibles ones for non logged in users. I’ve been researching for it but no success.
I know that Discourse enable us on creating private categories, but when i do it the topics and category itself become not visible for non logged in users.
Is there any tip i can do about it?
Thanks in advance!
cpradio
(cpradio)
2018 年 1 月 14 日午後 11:09
Isn’t that counter-intuitive? You want private topics, thus limiting access, but you want everyone to be able to see them?
I’m not sure I understand what the end-goal is here. Maybe dive further into what the customer wants exactly, as right now, it doesn’t seem clear yet.
@cpradio sorry for not explaining myself well..
My customer wants to categories and topics be visible but the user cannot go to the conversation inside the topic. Categories and topics must be visible but with a “lock” icon on it.
david
(David Taylor)
2018 年 1 月 14 日午後 11:14
You may be interested in this plugin. Make sure not to use it for anything sensitive (topic content is still available in search results)
This plugin allows you to restrict access to topic pages in a category. Topic titles will still show up in topic lists, search, user activity & digest emails. This is a great way to advertise the activity in a “members-only” category, which may charge for access.
It IS NOT designed to keep the contents of the category 100% private - if someone is determined enough they will be able to piece together the content from search results.
Each category has a couple of new settings in the Security tab…
@david thanks for replying, i think that your plugin is what i need to. I’ll try it and then i back here for feedbacks.
@david i liked the plugin. would it be able to set a specific url per category not only for all at same time?
Hi @david ,
i tried your plugin.
After configuring 2 categories my discourse went out of service with a 500 server error. After removing the plugin and restarting my forum it is working.
Here is the log:
/var/www/discourse/plugins/discourse-category-lockdown/plugin.rb:21:in `is_locked'
/var/www/discourse/plugins/discourse-category-lockdown/plugin.rb:77:in `is_locked_down'
(eval):43:in `_fast_attributes'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:467:in `rescue in attributes'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:455:in `attributes'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:479:in `_serializable_hash'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:361:in `serializable_hash'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer/associations.rb:124:in `block in serialize'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer/associations.rb:123:in `map'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer/associations.rb:123:in `serialize'
/var/www/discourse/lib/freedom_patches/ams_include_without_root.rb:55:in `include!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:367:in `block in include_associations!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:366:in `each_key'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:366:in `include_associations!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:480:in `_serializable_hash'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:345:in `as_json'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/json/encoding.rb:33:in `encode'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/json/encoding.rb:20:in `encode'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/core_ext/object/json.rb:39:in `to_json'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:333:in `to_json'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/multi_json-1.12.1/lib/multi_json/adapters/oj.rb:21:in `dump'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/multi_json-1.12.1/lib/multi_json/adapter.rb:25:in `dump'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/multi_json-1.12.1/lib/multi_json.rb:139:in `dump'
/var/www/discourse/lib/topic_list_responder.rb:14:in `block (2 levels) in respond_with_list'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/mime_responds.rb:201:in `respond_to'
/var/www/discourse/lib/topic_list_responder.rb:11:in `respond_with_list'
/var/www/discourse/app/controllers/list_controller.rb:91:in `block (2 levels) in <class:ListController>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-0.10.7/lib/mini_profiler/profiling_methods.rb:76:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:16:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.0/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:189:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:167:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/conditional_get.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:147:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/runtime.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-0.10.7/lib/mini_profiler/profiler.rb:171:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:702:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.1/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
david
(David Taylor)
2018 年 1 月 20 日午前 12:28
8
Thanks for the report, I’ll try and investigate soon and get back to you.
To answer your previous question, adding per-category URLs is a feature that could be added, but I’m unlikely to add it in the near future. If someone wanted to submit a PR with the feature I would be happy to accept it
That’s great Taylor.
Here are more logs:
/var/www/discourse/app/controllers/categories_controller.rb:41:in `block (2 levels) in index'
/var/www/discourse/app/controllers/categories_controller.rb:34:in `index'
/var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call'
/var/www/discourse/plugins/discourse-category-lockdown/plugin.rb:40:in `check_and_raise_exceptions'
/var/www/discourse/lib/topic_view.rb:46:in `initialize'
/var/www/discourse/app/controllers/topics_controller.rb:83:in `new'
/var/www/discourse/app/controllers/topics_controller.rb:83:in `show'
david
(David Taylor)
2018 年 1 月 20 日午前 11:37
10
Thanks @david , i’ll try it.
