Mermaid JS プラグイン
Repo: GitHub - unfoldingWord/discourse-mermaid: Adds the Mermaid JS library to discourse · GitHub
Overview
This plugin adds the Mermaid JS library to Discourse so that posts can make use of its features. It turns this:
[mermaid]
gantt
    title A Gantt Diagram
    dateFormat  YYYY-MM-DD
    section Section
    A task           :a1, 2014-01-01, 30d
    Another task     :after a1  , 20d
    section Another
    Task in sec      :2014-01-12  , 12d
    another task      : 24d
[/mermaid]
into this:
See the Mermaid JS site for documentation and more examples.
Installation
The installation notes are available at GitHub - unfoldingWord/discourse-mermaid: Adds the Mermaid JS library to discourse · GitHub (in short, just add it to app.yml).
Notes
Thanks to @j.jaffeux, version 0.0.3 of this plugin is much easier to install and the generated charts load reliably and immediately.
「いいね!」 30
This is very cool, some ideas for future work:
  1. email support here is going to be ultra weak cause it is likely to require very rich feature from email that you can not deliver
I would recommend adding a reduce_cooked email hook (see discourse/lib/pretty_text.rb at 4ad924bcf5acb6c99868887b2a402b7b5f289771 · discourse/discourse · GitHub ) you can use image magick to convert SVG to an image, create an upload, tie to post and then add it there. It is fiddly but would add value.
  1. This hack is interesting, cause you could make this wider and support graphviz GitHub - mdaines/viz-js: Graphviz in your browser · GitHub
「いいね!」 11
Can’t you vendor this lib so a user can skip this step? I believe GitHub - discourse/discourse-math: Official MathJax support for Discourse · GitHub does this.
「いいね!」 11
I’d love to, especially because I’m suspicious that might make the rendering more reliable. However, I can’t see how this happens, can you point me to something more specific?
Hi @jag3773,
I made a PR to this plugin project. It’s now fully lazy loaded and you don ’t need to add anything in your header. Enjoy!
https://github.com/unfoldingWord-dev/discourse-mermaid/pull/1
「いいね!」 13
Thanks @j.jaffeux ! As you saw, I merged in your PR and the results are far superior. The charts now load reliably and nearly instantly. I’ve updated the OP along these lines.
「いいね!」 7
Really love this plugin, it is very fun to use when you get instant updates in the editor preview pane :smiley:
Is there an easy way to make the plugin work better with dark themes?
There seems to be some example css in https://github.com/knsv/mermaid/tree/master/src/themes but I’m not sure what parts of it I would need to copy over to the theme CSS to make it the default for charts
Right now it looks like this with the bundled Dark theme, I would like to at least make all text and arrows white :
I’ll add one more thing to my wishlist, it would be great to have a composer button for Mermaid that could insert some example charts and have a link to the documentation site to make it easier for new users to discover all the functionality of the script.
I started looking for a generic toolbar customizer plugin to insert the snippets I need but it doesn’t look like anyone has made one. It would probably make more sense for each plugin to manage their own toolbar extensions anyway.
I totally agree, the instant updates in the preview pane are awesome!
I see how it doesn’t look great with the Dark theme :frowning: . Unfortunately, I don’t have the know how or capacity to work on a fix for that. However, I would gladly accept a PR that introduces a solution.
Node styling, as described in https://mermaidjs.github.io/flowchart.html does work. But that may be of limited usefulness in addressing the Dark theme issue.
Mermaid has a few themes in their repo, which I imagine you’d be able to select either with a site setting or something. My wild guess would be that this turns into
mermaid.init({ theme: 'dark' }, $mermaid)
Unfortunately none of the current ones (options are ‘dark’, ‘forest’, and ‘neutral’) really look good with DIscourse’s dark theme (they all have black text labels), so my recommendation here for someone willing to work on this (not me sorry :mermaid:)
Is it possible to support the render of the chart while printing (via ctrl+p) when using this mermaid plugin?
Simplest would be just to use the graphviz plugin instead
「いいね!」 4
@sam Thanks for the link
プラグインをありがとうございます!Discourse チームにとって非常に役立ちます。
mermaidJS を v8.10.1 に更新しました。GitHub の @rishabhlakhotia さんに感謝します。
「いいね!」 4
フローチャートでは、一部のテキストが正しく表示されません。
特に、バッククォート `` を使用してフォーマットする必要がある場合です。
「**猫**が帽子の中にいる」
mermaid.live ではすべて問題ありません。
これはこのサンプルのテストです。
flowchart LR
subgraph "One"
  a("「**猫**\n帽子の中にいる」") -- "エッジラベル" --> b{「**犬**が豚の中にいる」}
end
subgraph "`**Two**`"
  c("「**猫**\n帽子の中にいる」") -- "`太字 **エッジラベル**`" --> d("犬が豚の中にいる")
end
Flowcharts Syntax | Mermaid のドキュメントより
テーマコンポーネント Discourse Mermaid をプラグインではなくこちらで利用していますが、例でも同様の結果が見られます。
flowchart LR
subgraph "One"
  a("`The **cat**
  in the hat`") -- "edge label" --> b{{"`The **dog** in the hog`"}}
end
  c("`The **cat**
  in the hat`") -- "`Bold **edge label**`" --> d("The dog in the hog")
end
ただし、リンク先の例は、完成したフローチャートで太字/斜体のテキストが表示されていないため、参考にしていません。(Markdown自体は表示されていませんが)
いくつか問い合わせてみます。 :slight_smile:
ありがとうございます。テーマコンポーネントを使用するように変更します。
最高のサンプルが必要な場合は、以下でサンプルをテストできます。
