MayusYT
(Marius S )
27 Enero, 2019 09:45
Hi!
I just bought a domain at Namecheap.com .
I have a server with just one IP and I would like to run Discourse on the port 8080 as 80 is already occupied by my website.
When I want to setup an A record for discourse with the port 8080, namecheap says that it’s not a valid IP adress.
Any help is highly appreciated!
uwe_keim
(Uwe Keim)
27 Enero, 2019 10:04
Ports are completely out-of-scope in terms of DNS.
DNS maps names to IP addresses.
The Domain Name System (DNS) is a hierarchical and distributed name service that provides a naming system for computers, services, and other resources on the Internet or other Internet Protocol (IP) networks. It associates various information with domain names (identification strings) assigned to each of the associated entities. Most prominently, it translates readily memorized domain names to the numerical IP addresses needed for locating and identifying computer services and devices with the ...
Port associations is done on your server, not in the DNS.
MayusYT
(Marius S )
27 Enero, 2019 10:05
So what should I use instead in this case?
You’re putting yourself in a very complex territory.
What I can suggest is to run discourse on a subdomain or in a subdirectory.
MayusYT
(Marius S )
27 Enero, 2019 10:23
Yeah, I want to run it on a subdomain! But I don’t know how to tell my nginx proxy that you’re coming from the subdomain.
Create an A Record for sub.example.com with the IP address where You host forum
Then in nginx proxy,
use server_name sub.example.com;
And forward all requests to docker container running discourse.
MayusYT
(Marius S )
27 Enero, 2019 10:26
7
ooooh! Didn’t think of that! Thank you so much!
