no_email_found is still a problem
@zogstrip, I still have many mails not being sent because of no_email_found as reported earlier here:
1/ Are you running latest?
2/ What types of emails are not being sent?
Yes, running latest.
Types are digest and user_mentioned (there are no other types so far). However, mails to me (admin) do get through. This has been happening starting 28 January. The day before everything was fine.
I am also seeing A LOT of this.
I can definitely see that happening in production but not in development mode. So I added more logs to try to identify the source of the error
https://github.com/discourse/discourse/commit/4ad5660615a4026b332a137a3977cd4a0d6e3b63
Can you guys update and ping me in ~ 6 hours (or until the next digest job) with more info?
12+ hours on, I haven’t seen the issue again. I’ll keep checking.
@zogstrip, it happened many times again. No idea where you logged it, though. But you can use your admin login to see for yourself on my instance, if you like.
Thanks for your cooperation, I figured it out :wink: Turns out that when there are not enough topics to send a digest we pass a “NullMail” object to the “EmailSender” class. It didn’t help that the API changed in rails 4.2.0
https://github.com/discourse/discourse/commit/52a66826907bebe81b13ea6bd417f13a05443507
Great that you found that out! But… it also happens with user_posted. Does your fix fix that as well?
I only checked for digest, checking now for user_posted (it might be another issue, but with the same result).
Not sure how to reproduce for user_posted. Might have been already fixed. Let me know if it happens again.
I think they’ve all been fixed. I just saw a whole bunch of mailing_list and user_posted mails go out successfully. No digests yet, btw…
This topic was automatically closed after 2 days. New replies are no longer allowed.
