إضافة OAUTH الأساسية وعنوان URL لإعادة التوجيه
Hey guys,
how can I configure how discourse generates the redirect url. My problem is that my oauth provider configured this (and can´t change it due to conventions):
https://…/auth/oauth2/realms/root/realms/../authorize?client_id=…&redirect_uri=https://…/auth/oauth2/callback&response_type=code&scope=openid+profile+email&state=..
and my discourse instance generates this:
https://…/auth/oauth2/realms/root/realms/../authorize?client_id=…&redirect_uri=https://…/auth/oauth2_basic/callback&response_type=code&scope=openid+profile+email&state=..
How can I change this ?
Thanks and greetings,
Julian
The callback URL is not configurable on Discourse. The only way to change it would be to create a copy of the plugin and modify its code.
This is quite unusual, normally the consumer can define the callback URL
Hi there,
then I’ll have to speak firm words with him :slight_smile:
Thanks man, I don’t want to change the code of the plugin … wouldn’t make too much sense, would it? ..
Cheers, Wurzelseppi
