My coworker asked me about the blue ring around someone’s picture. How should I explain this feature and how its helpful to community members? They were just wondering what it means.
Thanks!
Emma
Thanks!
Emma
Original poster - Topic creator / first poster. (First avatar in the users list)
Most recent poster - Recent replier / last poster in the topic. (Last avatar in the users list normally)
When Original poster and Most recent poster are same then instead of displaying the same avatar twice in both first and last places it will be displayed in the first place with blue ring. So it simply means the topic creator is the last replier.
thank you so much for the explanation!
Best,
Emma
Anybody find this blue ring useful? Or clear?
It’s superior to duplicating the avatar twice, I’ll tell you that. Duplication is noisy.
Hi @schungx
Now that I understand it, I definitely find it useful! ![]()
こんにちは。
最も最近の投稿者のアイコンをユーザーリストの最後に表示するように定義する設定オプションはどれですか?設定方法が見つかりませんでした。
いいえ。デフォルトではそのようになっています。
