cfstras
(Claus Strasburger)
18.Июль.2013 15:53:04
This plugin adds the Konami Code to Discourse.
When invoked, magic happens.
https://github.com/cfstras/discourse-konami
It’s built on Konami-JS , which made this really easy :)
To install, just open your Docker container’s app.yml and be sure to have the following:
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
# other plugins...
- git clone https://github.com/cfstras/discourse-konami.git
Now, ./launcher rebuild and off we go!
Open Discourse and ↑ ↑ ↓ ↓ ← → ← → B A Enter !
Suggestions and patches are highly welcome.
13 лайков
jbruni
(J. Bruni)
18.Июль.2013 16:06:24
Nice as a small sample of what is necessary to build and install an extension.
I agree with @jbruni this is a great idea for a sample plugin or extension. Fun and actually somewhat useful!
cfstras
(Claus Strasburger)
18.Июль.2013 16:26:09
I based it off of Tutorial: Your first Discourse plugin , so thanks to @danneu for that!
Every site should have the Konami Code
x0rg
(Raffaele Di Fazio)
18.Июль.2013 20:24:33
Pretty cool! I wanted to do something like that.. do you have an idea for something similar to this to implement? I wanted to implement a simple plugin just to start with discourse…
Someone needs to update this to work with Discourse 1.3!
cfstras
(Claus Strasburger)
20.Март.2015 10:32:28
7
Done! was a quick fix.
Just ensure to put
in the plugins section of your app.yml.
(Sadly, I can’t edit my first post…)
dosch
(dosch)
15.Март.2017 09:27:59
8
Great! I activated it
Now, is there a way to award a badge when a user does the konami code ?
Doesn’t look like it straight off. It would probably need to be modified in order to trigger a badge grant api call or an entry into the database and a badge query from that.
varun21
(Varun Sharma)
18.Январь.2022 09:14:47
10
Итак, что именно оно делает? Есть ли демо / видео / пример?
osioke
(Osioke Itseuwa)
18.Январь.2022 10:08:15
11
Смотрите пост автора темы, я только что обновил его
varun21
(Varun Sharma)
18.Январь.2022 10:10:05
12
Да, только что перекомпилировал. Твоя тайна в безопасности
