Referência de enquetes: bugs agindo de forma estranha (ou não funcionando de forma alguma)
Polls, alone, in the current post are fine.
However, if you reference one… <I tried to find a poll in this forum, but could not find one, so see my example below>
https://forum.imperium42.com/t/the-forums-new-default-theme-is-dark/71825
You can see a “show results” btn:
However, clicking it does nothing. Also note the preview text shows “0 voters”.
If you click the top right arrow to dropdown more info:
Everything is 0.
However, clicking inside:
https://forum.imperium42.com/t/should-we-change-the-default-forum-theme-to-dark/46439
34 voters
with results
3 curtidas
Do you mean quoting a poll?
I think we should stop trying to do some of this fancy @zogstrip
2 curtidas
Yeah, quoting a poll doesn’t work. Will fix.
3 curtidas
The onebox will now only show a link to the poll instead of it’s content thank to @nbianca’s work.
@maja, can you have a look at how easy/hard it would be to show the polls data when clicking the top right arrow to “embed” the whole post?
1 curtida
I’ve made the changes to show the polls:
https://github.com/discourse/discourse/pull/7768/files
7 curtidas
