8BIT
16.Май.2019 17:29:27
everything’s updated:
but, when you visit a post, you don’t actually see the post content:
you see the title but nothing after it.
example:
https://thebitcoin.pub/t/something-is-happening-in-the-nations-capital/56101/1
so, i turned off all of the themes in admin, just leaving these two:
but, it doesn’t seem like a theme issue… help?
Looks like an issue with the retort plugin, I can see an error in the console
content appears when in safe mode
Stephen
(Stephen)
16.Май.2019 17:40:40
The default theme can be modified too, create a new theme based on the light colour scheme and try that.
It works using safe-mode:
It’s likely to be a plugin.
pfaffman
(Jay Pfaffman)
16.Май.2019 17:46:55
Ah. I think the problem is that I get confused about those check-boxes in safe-mode. I thought that I’d disabled the current theme and left the plugins, but instead, I kept the theme and removed the plugins.
@8BIT . I’m removing the plugin now. You’ll be back up in a few minutes.
8BIT
16.Май.2019 17:54:53
Whoot. Thanks! Appreciate the support!!
Falco
(Falco)
16.Май.2019 18:59:23
That sounds like the plugin broke because of the Lodash update.
j.jaffeux
(Joffrey Jaffeux)
17.Май.2019 05:44:07
7
9 лайков
j.jaffeux
(Joffrey Jaffeux)
Закрыл(а) тему
17.Май.2019 16:00:13
8
This topic was automatically closed after 10 hours. New replies are no longer allowed.
