API de suppression du nombre de messages non lus
Bonjour l’équipe,
Existe-t-il une API pour effacer le compteur de non-lus pour un sujet répondu ?
J’ai procédé à une rétro-ingénierie et appelé l’API
http://192.168.131.180/t/{topic_id}/{posts_count}.json?track_visit=true&forceLoad=true&_={timestamp}&api_key={user_api_key}
et
http://192.168.131.180/topics/timings
mais cela ne fonctionne pas.
See Reverse engineer the Discourse API
I have done reverse engineering and called api
and
but it’s not working.
I looked through code and second request should have done the trick. I tried and I was successful in clearing the count. Attaching screenshot of my request which got a 200 OK status and cleared count.
Timings[6] should be timings[posts_count]. You can add just one timings[posts_count] and clearing should work. I think other timings[posts_count - x] are for tracking purpose.
Have a try and let me know if you have any questions.
Thanks
