Problemi durante l'uso di Discourse come SSO
Hi there,
I’m working on using Discourse as SSO, however whenever I make the call to “/session/sso_provider” I get an error. The log shows the following:
NoMethodError (undefined method match' for nil:NilClass) /var/www/discourse/app/services/wildcard_domain_checker.rb:7:in check_domain’
I’m using build v2.3.0.beta8 +44
Is this a known issue?
Thanks,
Iscle
Any news? Still happening with the latest build…
Thanks.
What is the value of sso provider secrets in your site? We changed how the setting work, and now it’s a list of (URL, secret) tuples. Sounds like you have a tuple where the URL is missing?
Hi Rafael,
Thanks for your answer, I just solved the issue!
It turns out I was missing “https://” on the return url (in the backend of my app)! Very stupid mistake, I know… Maybe you can add a check to avoid that from happening?
Anyway, thanks again :smiley:
Have a nice day!
