Go to the following post:
Try load the full quote and you’ll get the Loading... text and it’ll stay there. You can’t toggle it back either; it’s stuck in that operation.
This is more or less by design.. the only improvement would be for “loading…” to say “post was deleted” instead. So it’s a feature req.
Well, clicking the toggle also gets you into an unrecoverable state (without refresh) where you can’t toggle back to the on-page quote. That’s a minor bug imo.
As for how to keep users from encountering it, I suppose the simplest fix of all would be to not display the toggle-arrow if the topic no longer exists.
Can’t know that until we check on click.
Okay, but the code can tell when the request failed, and go back to the original state. We could fix that.
This “issue” is still here on Meta (example in the OP of this topic https://meta.discourse.org/t/cross-origin-framing/26984) exactly as described by @erlend_sh
I think that new user can be really in difficult to understand what’s happening, the only way to see what is wrong is open the browser console and look at the error Not Found.
Change Loading... with This post was deleted, as @codinghorror said above, is a good compromise to me.
Sure can you make that change @eviltrout? This one is long overdue.
Good ol’ @neil did it!
Кажется, у нас здесь своего рода регресс. Посмотрите на встроенную ссылку Manually update Discourse and Docker image to latest - #112 от Dean: там отображается бесконечная «загрузка». Это всё ещё работает для простого цитирования, содержащего ссылку, но не для удалённой связанной темы/сообщения.
Таким образом, это работает только с очень простым текстом цитаты, без ссылок внутри.
Is this fixable easily @eviltrout? Maybe take a peek Monday.
Looks like the bug was where the post was in a deleted topic (but the post was not deleted) it would return InvalidAccess instead of a 404. This fixes it and shows the trash can again.
https://github.com/discourse/discourse/commit/89a1b34480e89e8dc1d47c749f08ed1225a173e4
