'X-Frame-Options' を 'sameorigin' に設定したため、フレームに表示を拒否しました
I use discourse as the commenting system for my food blog.
Recently the page stopped showing the comments at the bottom and this error shows in the developer console.
Not sure what I did. I haven’t changed any settings in a long time.
How can I fix this?
What are the x-frame-options headers returning on your parent domain? You can inspect headers in the browser F12 console.
Per the docs
SAMEORIGIN
The page can only be displayed in a frame on the same origin as the page itself. The spec leaves it up to browser vendors to decide whether this option applies to the top level, the parent, or the whole chain, although it is argued that the option is not very useful unless all ancestors are also in the same origin.
This is the response. It says ALLOWALL but no luck..
curl -X HEAD -I https://www.alittlebitofspice.com/indian-tandoori-chicken-in-oven-recipe
HTTP/2 200
date: Fri, 11 May 2018 21:05:18 GMT
content-type: text/html; charset=UTF-8
set-cookie: __cfduid=d9f19aff1bfc853cdb31d03b2f1813b8b1526072718; expires=Sat, 11-May-19 21:05:18 GMT; path=/; domain=.alittlebitofspice.com; HttpOnly
vary: Accept-Encoding
link: <https://www.alittlebitofspice.com/wp-json/>; rel="https://api.w.org/"
link: <https://wp.me/p90p7a-r6v>; rel=shortlink
x-frame-options: ALLOWALL
x-content-type-options: nosniff
x-cache: uncached
cache-control: public
x-nginx-cache-status: HIT
expect-ct: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
server: cloudflare
cf-ray: 41979a5a5ee2a02e-SLC
Not sure. You should compare with my blog, which is working fine on the latest version of Discourse, and showing comments below the blog post: To Serve Man, with Software
Strange. You don’t have a x-frame-options. Maybe I should just hide it. But that does not seem right.
curl -X HEAD -I https://blog.codinghorror.com/to-serve-man-with-software/
HTTP/2 200
date: Fri, 11 May 2018 21:29:45 GMT
content-type: text/html; charset=utf-8
set-cookie: __cfduid=d7dbb0eaab840a338093436369c32d7c91526074185; expires=Sat, 11-May-19 21:29:45 GMT; path=/; domain=.codinghorror.com; HttpOnly
status: 200 OK
x-powered-by: Express,Phusion Passenger 5.2.3
cache-control: public, max-age=0
last-modified: Fri, 11 May 2018 21:30:58 GMT
x-ghost-cache-status: From Cache
x-request-id: c61b67b333b14f47e359c57135e73eb7
server: cloudflare
cf-ray: 4197be29698da022-SLC
I am pretty sure that header is coming from your blogging software, not Discourse. So my guess is that you upgraded it recently and someone added the extra header.
I was having this same problem (right now, with up-to-the-moment Ghost and Discourse), and fixed it by changing the Discourse site, not the parent Ghost site.
And it was a struggle to get rid of the x-frame-options headers coming from Discourse! I ended up with this in my Nginx site configuration:
location / {
        proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock:;
        proxy_set_header Host $http_host;
        proxy_http_version 1.1;
        proxy_set_header X-Forwarded-Proto https;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_hide_header 'x-frame-options';
        add_header x-frame-options ALLOWALL;
