Searching for URLs doesn't work
This post includes the URL http://example.org/path#anchor
(The Google search result work as a valid fallback, but it would be still better if Discourse could return these posts) .
I don’t think URL searching is supported at the current time, so this would be a feature request. The domain name is probably tokenized like language words. Is URL searching something postgres has support for @sam?
Note that using quotes does work, though
Something is definitely off here cause that string should be tokenized.
Nice bug report, this is fixed per:
https://github.com/discourse/discourse/commit/57a1190b07b20d48e14e12f17a42d24b0acf37ce
Requires a re-index on broken posts (which you can do by editing)
This topic was automatically closed after 25 hours. New replies are no longer allowed.
