Gmail スレッドの送信者名
A typical Gmail thread will look like this:
Note that the sender names are listed (with an ellipsis if there are too many)
With discourse they look like this:
There are really 98 different senders in that thread but on first look it appears they have all come from the same person!
So many times this messes me up when I think e.g. “Why is X sending another message on this thread? I thought they just posted 2 minutes ago?” (Incidentally I have the same experience with Github notifications.)
It also means that new contributors to the thread are not as visible as they would otherwise be:
Compare:
(clearly a new contribution from Jason) with
The latter unread email is actually from a user named Sergio, not Knightrider.
Can anything can be done about this?
I assume that what causes it is all the Discourse emails coming from the same ‘From’ address. Could we not have a separate ‘From’ address on the Discourse site’s domain unique to each user? So I might be user-32q7qwhfwp@meta.discourse.com and any notifications of posts I’ve sent would come from that address?
Would this cause deliverability issues? I would hope not as long as the meta.discourse.com domain is verified with Mailgun or whoever…
Or maybe I’m wrong about the issue here. Thoughts welcome.
「いいね!」 6
Yeah maybe we should use plus addressing here, change:
From: Sam Saffron via Discourse Meta <meta@discoursemail.com>
To:
From: Sam Saffron via Discourse Meta <meta+sam@discoursemail.com>
Seems to me like a small change and it could make gmail look nicer.
@gerhard any concerns here? If not, go ahead and make the change.
Are we 100% sure every site running Discourse supports plus addressing? I know it is required for incoming mail, so perhaps that’s a safe assumption?
Thing is, nobody is even meant to email this address, the reply to here goes to discourse mail.
Probably fine, just worried about possible side effects. I support trying it out, but at the same time it feels a bit strange to me as we are “personalizing” the email address so the odds of someone seeing it and assuming that
is somehow an email they can use to reply to Sam.. is much higher now versus
Thinking about this a bit more I feel this is kind of a nasty hack and has the possibility to do more harm than good.
「いいね!」 5
この件に関する更新情報:どうやら Gmail がこれを解決したようです。
同じスレッドはこちらです(今はメッセージが 2 件追加されていますが、それは関係ありません):
だれか、これがいつ、どのようにして起きたかご存知ですか?
スレッドの参加者リストを作成する際に、送信元メールアドレスではなく名前を一致させるように変更しただけなのかもしれません。
それは良いですね!私の知る限り、1 月以来当方側での変更はありません。
