SetUpComponent not being called for topic list tags plugin outlet
If I add a plugin outlet in list item,
ie <plugin name>/assests/javascripts/discourse/templates/list/connectors/topic-list-tags/<unique name>.raw.hbs
Where should I add the js.es6 file for this outlet?
I tried it in following location, but it didnt work
ie <plugin name>/assests/javascripts/discourse/list/connectors/topic-list-tags/<unique-name>.js.es6
export default {
  setupComponent(args, component) {
The topic-list-tags plugin outlet has been removed in
https://github.com/discourse/discourse/commit/f918951d42234790938da442a768c2bf80f87069
I believe you can add tags to the list via the plugin-api
https://github.com/discourse/discourse/blob/master/app/assets/javascripts/discourse/lib/plugin-api.js.es6#L394-L410
Thanks for your reply. I see there is another plugin outlet “topic-list-after-title”.
I added the raw.hbs file in the “topic-list-after-title” folder. I added some test text in the raw.hbs file, and I was able to view the same in the discourse site.
But as mentioned here , if we add corresponding js.es6 file and
export default {
    component.set('today', new Date());
the setUpComponent will be called before rending the hbs connector file.
But in my case, I am able to view the text, but the above function is not called.
raw.hbs file location : my-plugin/javascripts/discourse/templates/connectors/topic-list-after-title/test-topic-list-after-title.raw.hbs
js.es6 file location : my-plugin/javascripts/discourse/connectors/topic-list-after-title/test-topic-list-after-title.js.es6
我也遇到了同样的问题。你找到解决办法了吗?
编辑:如果有人想查找如何为这个 outlet 的 raw hbs 添加计算属性的方法:What is the difference between raw.hbs handlerbar files and only .hbs handlerbar files? - #4 by spirobel
