Short code to insert Join/Leave group button into a post
To integrate group memberships more fluidly into the community-building aspects of Discourse posts, it would helpful to have a short-cut for inserting the join group interface directly into any post.
For example, it could be a code added to the end of a group name, e.g. @volunteers_group:join. Whether the button appears as +Join or +Request to join or -Leave will depend on the users current membership and group security.
The button should be displayed with the group name, as well as a note indicating what priviliges joining that group offers, i.e. is it a public/private group; which categories have added visibility.
The feature would give administrators of projects the ability to bootstrap teams very efficiently.
Can’t you just send out invites which contain a group membership? As I understand it, invites work to add existing users to a group, correct @techapj?
I think the use case is around self service, the groups page is kind of hidden, it would be a fairly complex change permission wise to support the proposal though
Here’s an example post.
Welcome to the conference!
There are three content streams being featured, but each attendee should pick only one to focus on. Select which group to join below. We are also looking for 5 jury members to choose winning projects. Apply if interested.
Stream 1: Fruit – JOIN
Stream 2: Computers – JOIN
Stream 3: Waterfalls – JOIN
Apply to join the conference jury – APPLY
Thank you
Dr. Neylor
Currently the only way to add existing user to a group via invite is by using Invite Link (prepared via Invite Token), more details here:
The Invite Link can serve this case because the user will only be added to a group if they click on that link.
So you’re saying that there is already a method in the codebase for generating this link, contrary to @sam’s concern, and it’s mostly a matter of building a new UI around generating the link?
It’s not exactly what you are looking for and what Sam is proposing, it’s kind of a workaround which you can use if it works for you.
I think that “Stream 1…” example would still work pretty well if those “JOIN” buttons were appropriately styled and just linked to the group page. I strongly doubt you’d lose many people in the onboard funnel with that extra click.
Although far from a perfect equivalent, I do hate it when websites use that interactive “follow us” Twitter widget which asks me to follow them immediately instead of taking me to their Twitter stream so I can see if I’m actually interested in what they’re putting out.
Sort of, we should allow for /groups?only-show-group=bla which would be a very easy change and take away a ton of the current noise of simply linking to the groups page. (eg: what if there are 100 groups)
Maybe, the equivalent for topics is categories and tags.. should groups also have categories and tags?
Поднимаю эту тему из небытия: я поискал, но не нашёл хорошего решения. Мы хотим централизовать множество настроек сайта в одном месте. Нужен вариант «сообщать мне, если чат-бот упомянет группу @xyz» с переключателем «да/нет», который ведёт к обработчику вступления/выхода из группы. Ссылка на groups/?showonly= — это следующее лучшее решение, но «вступление» в «группу настроек» не интуитивно понятно для многих наших пользователей.
Мне нравятся идеи, обсуждаемые в этой теме. Группы, безусловно, заслуживают внимания, хотя в данный момент это не является приоритетом для команды. Не стесняйтесь реализовать улучшения в виде компонента темы, чтобы попробовать их в действии!
Одна мысль, которая пришла мне в голову: мы могли бы добавить кнопки «Вступить/Покинуть» на карточке пользователя для групп, что позволит людям свободно вступать в них и покидать их.
Так, например, пост, который @trudat написал выше, можно было бы переписать следующим образом:
