Solution for privateemail configurations
several users tried to configure Discourse with privateemail without luck including me. you can read more about this problem here “https://meta.discourse.org/t/cant-get-admin-email-to-send-working-with-using-namecheap-email-server/57423”. but after a month of investigations, i finally found the solution.
the main problem was the “from” field
discourse by default use noreply@yourdomain.com for notification emails but privateemail SMTP server needs the mail address of the mailbox you have.
there is no why to solve this issue while installation @codinghorror so after installation you have to re-open containers/app.yml file and make the following adjustments.
SMTP Configurations
  DISCOURSE_SMTP_ADDRESS: mail.privateemail.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: mailBox@yourdomain.com
  DISCOURSE_SMTP_PASSWORD: "****************"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true          # (optional, default true)
1- use port 587
2- use your mailbox address instead of mailBox@yourdomain.com
3- uncomment DISCOURSE_SMTP_ENABLE_START_TLS and set it to true
Notification E-Mails Configurations
At the end of the file you would find
## Any custom commands to run after building
run:
  - exec: echo "Beginning of custom commands"
  ## If you want to set the 'From' email address for your first registration, uncomment and change:
  ## After getting the first signup email, re-comment the line. It only needs to run once.
  #- exec: rails r "SiteSetting.notification_email='mailBox@yourdomain.com'"
  - exec: echo "End of custom commands"
1- uncomment - exec: rails r "SiteSetting.notification_email='mailBox@yourdomain.com'"
now ./launcher rebuild app and have fun :wink:
Блестящая работа, спасибо. Это следует включить в официальную документацию. Ура.
Для новичков, которые не знают, где найти containers/app.yml, вот полный путь: /var/discourse/containers/app.yml
Я искал решение этой же проблемы уже около 4 часов.
Согласен, это должно быть включено в документацию.
Пожалуйста, очень прошу.
Этот пост и спустя 5 лет помогает решать проблемы. Большое спасибо за то, что поделились этим.
Подтверждаю, что это всё ещё работает по состоянию на 04.06.2025 :smiley:
