Solved topics should automatically close, after a delay?
If there can be setting that as soon as a topic is marked solved it should close immediately or after maybe an hour or a specified period which can be set for each category..
I think it would be great if this was added to the system :slight_smile:
7 Mi Piace
What do you think about this @sam? Since you worked so heavily on solved plugin.
Could you briefly explain a use case for this? Do you often see a topic continue past its logical conclusion long after it has been marked as solved?
Yes many times after original poster(first learner issue) is solved and a moderator doesn’t close it we get other learners throwing in their questions.
Note, we have had this setting for quite a while now :slight_smile:
solved topics auto close hours site setting
4 Mi Piace
