SidV
Hello Team, in transifex, I think there is a problem with this key:
user.destroy_reasons.same_ip_address
It said:
Is it ok that “1%i p_address%” ?
Can you check it?
Other key with problems:
js.post.actions.people.like_capped
Please check the translations:
- For 1:
and {{count}} other liked this
- For others:
and {{count}} others liked this
Is that ok?
CC: @neil
gerhard
(Gerhard Schlager)
That’s a bug in the Transifex UI. I suggest you enable the “raw editor mode”. Makes life a lot easier in my opinion.
neil
(Neil Lalonde)
Looks like @zogstrip added it.
same_ip_address: "Same IP address (%ip_address%) as other users"
Does that work? I’m pretty sure it should be %{ip_address}.
「いいね!」 4
