windy
(Walker Crouse)
21.Декабрь.2016 17:40:14
I know there are a few other posts about this, but none of them were able to solve my problem. Everything else in our SSO implementation works fine; this is the only thing that’s not working as expected. I’ve tried setting avatar_force_update to both true and 1 to no avail.
Code snippet w/ verbose log output: SSO.scala · GitHub
Any insight is much appreciated, thanks.
alehandrof
(Alex Armstrong)
21.Декабрь.2016 18:23:57
If you’re in development, maybe it’s this:
Edit: nevermind, you’re using non-local URLs.
Falco
(Falco)
23.Декабрь.2016 16:39:29
DId you enable sso overrides avatar ?
windy
(Walker Crouse)
23.Декабрь.2016 16:51:40
Yes I did. Sorry should have mentioned that.
windy
(Walker Crouse)
27.Декабрь.2016 22:16:27
@Falco Any other possible fixes you can think of? Kind of important I work this out.
Falco
(Falco)
27.Декабрь.2016 22:47:18
7
In your gist avatar_force_update isn’t set, did you manage to make it true in verbose logging?
windy
(Walker Crouse)
27.Декабрь.2016 23:49:52
8
Yes sorry, I tried both with and without, I had another instance where it was set to true and still no update.
Falco
(Falco)
28.Декабрь.2016 00:00:52
9
So even with verbose_logging showing avatar_force_update = true the avatar isn’t updated?
Are you runiing against a production docker instance?
windy
(Walker Crouse)
28.Декабрь.2016 00:14:42
10
Yeah, I tested on both production and a dev instance on OS X.
EDIT: Just realized I haven’t tested avatar_force_update on prod, will try that and report back.
windy
(Walker Crouse)
28.Декабрь.2016 00:47:47
11
Ok just tested on our production docker instance @Falco and still no update with avatar_force_update: true in verbose logging.
Falco
(Falco)
28.Декабрь.2016 01:17:34
12
The user already exists or is he being created as part of the SSO log in?
Also is /sidekiq with a queue? Any errors regarding DownloadAvatarFromUrl?
Also try this in a rails console in a production instance:
user = User.find_by_email(AUSEREMAILHERE)
Jobs.enqueue(:download_avatar_from_url, url: 'http://mycoolavatar.png', user_id: user.id)
and watch logs.
lukegb
(Luke Granger Brown)
17.Январь.2017 01:19:41
13
For what it’s worth, it works fine. The main problem is that sso_overrides_avatar is misleadingly named, because it won’t, in fact, override a Gravatar set on a user.
The call to download_avatar_from_url here:
if SiteSetting.sso_overrides_name && user.name != name && name.present?
user.name = name || User.suggest_name(username.blank? ? email : username)
end
avatar_missing = user.uploaded_avatar_id.nil? || !Upload.exists?(user.uploaded_avatar_id)
if (avatar_missing || avatar_force_update || SiteSetting.sso_overrides_avatar) && avatar_url.present?
avatar_changed = sso_record.external_avatar_url != avatar_url
if avatar_force_update || avatar_changed || avatar_missing
Jobs.enqueue(:download_avatar_from_url, url: avatar_url, user_id: user.id)
end
end
# change external attributes for sso record
sso_record.external_username = username
sso_record.external_email = email
sso_record.external_name = name
sso_record.external_avatar_url = avatar_url
end
end
doesn’t pass override_gravatar, so:
def execute(args)
url = args[:url]
user_id = args[:user_id]
raise Discourse::InvalidParameters.new(:url) if url.blank?
raise Discourse::InvalidParameters.new(:user_id) if user_id.blank?
return unless user = User.find_by(id: user_id)
UserAvatar.import_url_for_user(url, user, override_gravatar: args[:override_gravatar])
end
end
end
doesn’t pass on override_gravatar, so:
ext = FastImage.type(tempfile).to_s
tempfile.rewind
upload = Upload.create_for(user.id, tempfile, "external-avatar." + ext, File.size(tempfile.path), origin: avatar_url, image_type: "avatar")
user.create_user_avatar unless user.user_avatar
if !user.user_avatar.contains_upload?(upload.id)
user.user_avatar.update_columns(custom_upload_id: upload.id)
override_gravatar = !options || options[:override_gravatar]
if user.uploaded_avatar_id.nil? ||
!user.user_avatar.contains_upload?(user.uploaded_avatar_id) ||
override_gravatar
user.update_columns(uploaded_avatar_id: upload.id)
end
end
rescue => e
# skip saving, we are not connected to the net
won’t set it to the avatar from SSO.
Is this intentional behavior?
No it’s not. Feel free to do a pull request
techAPJ
(Arpit Jalan)
19.Январь.2017 05:26:10
15
lukegb:
Fixed via:
https://github.com/discourse/discourse/commit/0791c2c96636e9af5992d5d0ea6f991018cf4ef6
lukegb
20.Январь.2017 21:23:36
16
Thanks! I wasn’t sure if there was an obvious edgecase I’d missed
