SSO_SYNC funktioniert nicht
Hi Guys
I need some assistance with the /admin/users/sso_sync end point.
Using postman, I am trying to update an email address using this end point, but postman is returning a HTML page as response (which is basically the landing page of my application where discourse is integrated).
Im doing a POST to:
https:{my domain}/admin/users/sync_sso
With body:
	"email":"test@gmail.com",
	"external_id":"xxxxxxxxxxxxxxxxxxxxxxxxxxxx",
	"require_activation":"false",
	"api_key":"xxxxxxxxxxxxx",
	"api_username":"admin users email address"
For the api_username, i have tried both admin user’s email address as well as username, but none works.
Is the api_username something else?
Can someone advise where Im going wrong.
Regards
As per
You have to use the following:
$api_username = 'system';
thanks for that. Using the api_username=system takes me one step further, but I am now getting an error regarding an invalid ‘sig’, which is not something i pass neither suggested to pass?
RuntimeError (Bad signature for payload sso: sig: expected sig: a03011b1a83a925095b984c265fbe1e65f3351e6edfee38cbbf1b3c1015630f2) /var/www/discourse/lib/single_sign_on.rb:30:in parse’`
any ideas?
I’m not very familiar with that endpoint and @simon wrote that howto so maybe he can help!
Edit:
are you initializing sig as:
$sig = hash_hmac( 'sha256', $sso_payload, $sso_secret );
No, I am not. Reading the documentation, I assumed I could call the end point with payload excluding nonce, sig and it would work. @sam, could you please advise on this too, have an urgent deadline to meet on this.
Using a Java application, I simply want to make a rest call to that end point to update the email, silently.
This is correct. You do not need the nonce in the payload for the sync_sso route. The body of the POST request needs the following parameters: sso, sig, api_key, api_username.
To see how to create the sso and sig parameters, read the ‘Setup the SSO parameters’ section of this topic: Sync DiscourseConnect user data with the sync_sso route.
The return value of a successful call to /admin/users/sync_sso is a Discourse User object.
thank you simon, i have it almost working now.
