The setting seems to have disappeared unless something changed that I couldn’t find by searching in the forum?
I am on the latest tests passed and tagging is turned on.
cpradio
(cpradio)
03.Июнь.2018 22:30:22
I think this was combined in the Tags Admin UI, if you look there, I think there is a Tag group for Staff
Thank you! For others reference, more info is here:
Tag support is a core feature of Discourse. In this How-To I’ll go through setting up a tag schema like Car Talk uses.
We’ll want to achieve these things:
Tags for car makes and car models.
Only allow the car make and model tags to be used in certain categories.
Car model tags can only be chosen if the matching car make tag is used.
Prerequisites
Tagging is enabled by default in Discourse (via the tagging_enabled site setting). If it was previously disabled, ensure it is turned on.
In a sc…
