[Tab] should work after "edit title" or using hotkeys
When you use the “edit title and category of this topic” button next to the title or e on the first post, Tab doesn’t do what I expect/hope it to do: Jump to the first input field there, then to the second and so on. Seems the focus stays on where you were before.
Sure can we improve this by explicitly setting focus @tgxworld? There is no mobile risk at all.
Re-categorized this to the bug category.
Fixed in
https://github.com/discourse/discourse/commit/31932813b782c70473a5f759cde1471ee610d828
Another bug I found which was quite bad is that opening a composer was sending 3 duplicated requests to the server. This has been fixed in
https://github.com/discourse/discourse/commit/3ff9133f857e57f82afed03a6c9b0aaa48f85fa6
I can’t reproduce this. Tabbing works fine for me.
@Sujan Thanks for reporting!
You are right, no idea what I saw back then. Problem (that you already fixed) is only present after usage of keyboard shotcuts.
