Themes and Styles?
I was going through the feature list and I wasn’t sure
but does Discourse use a theme/template/style setup at all.
And if so does it use a particular standard/framework?
@Oroton - far as i know… it uses CSS. And Theming Discourse is the most easiest way to do it, if u know the code ofcourse. admin. www.example.com/admin/customize/ - u have all options/features here needed to build a successfully good looking site. Good luck and cheers!
Thanks mate, is there catagory that lists existing themes and plugins?
cheers
https://meta.discourse.org/c/ux - is the category for themes and css tricks that people implemented and willing to share. :smile:
إعجاب واحد (1)
Not really, that is a category for discussion about the way Discourse UX works.
see also:
إعجابَين (2)
