HTTPS 有効化後のリダイレクト過多
I’m trying to enable https on an existing forum using this guide: Set up HTTPS support with Let's Encrypt
I ran ./discourse-setup and entered my email address for Let’s Encrypt, and then rebuilt the app.
However, now when I visit my server I’m getting this errors:
forum.happycoding.io redirected you too many times.
ERR_TOO_MANY_REDIRECTS
I’ve manually inspected app.yml and it appears that all of my settings are correct. I’m not using cloudflare or anything.
Is there a step I’m missing? Is there something special I need to consider when running my discourse on a subdomain?
As always, thanks for your time, and I appreciate any help anybody can offer!
I’m not sure what the problem could be. Could you try the unannounced discourse doctor and see if it sheds light?
git pull
./discourse-doctor
As always it turns out that I’m an idiot. I had some upper-case letters in my domain (forum.HappyCoding.io). Modifying the app.yml file to only user lower-case letters (forum.happycoding.io) solved the problem.
I noticed this when I looked at the output for disocurse-doctor, so thanks very much!
Btw, I found a similar thread with a similar problem here.
Great! That’s what it’s supposed to do!
Was it just printing the configuration information or was it something else?
Yeah, the discourse-doctor tool printed out the config data, which is where I saw the upper-case letters. That coupled with seeing this post and remembering encountering another problem with upper-case letters finally clicked everything into place in my brain.
Maybe you can extend doctor to warn, or we can add a stop warning in setup, when people put uppercase characters in the domain name?
Or launcher could downcase the domain main name.
Sure, whatever works and is easy!
