Anforderungen an das Vertrauenslevel über die API
Is possible to get the Trust Level Requirements of an user from the API?
Just to check, are you referring to this page?
If so, you should be able to find the require API call via Reverse engineer the Discourse API.
Yep, that page
Okey, I’ll try :+1:
Found, thank you!
The URL is: /admin/users/id.json
