Undefinierte Methode `resolve_baked_field` beim Precompilen von Themes
What would be a good method to diagnose
precompile target: desktop_theme
rake aborted!
NoMethodError: undefined method `resolve_baked_field' for nil:NilClass
Step :one: would be to be on latest, are you?
After that I would disable theme by theme to find which is the problem one.
Yes .. this was bulk standard
./launcher rebuild app
on a staging site which as I understand it gets the latest version.
How do you disable themes on an instance that is not running?
Does it give you more than that? Typically, there’s a backtrace there.
Based on the solution another post with a similar issue.
I did the following
  1. Added DONT_PRECOMPILE_CSS: 1 to /var/discourse/containers/app.yml
  2. /var/discourse/launcher rebuild app which worked
  3. Selected a default theme in {{host}}/admin/customize/themes … no default theme was selected.
  4. Commented out DONT_PRECOMPILE_CSS: 1 in /var/discourse/containers/app.yml
  5. /var/discourse/launcher rebuild app again, which worked.
