URL 不支持越南语 不支持越南语
If you click to this link: URL do not support Vietnamese Không hỗ trợ tiếng Việt
You can see that: for Vietnamese language “Không hỗ trợ tiếng Việt”, it should be “khong-ho-tro-tieng-viet”, but it changed to “khong-h-tr-ti-ng-vi-t”. It makes this link look ugly.
Please help me to fix it.
It doesn’t work on meta, because the default_locale is set to English. But it will work when you change the default_locale site setting to Vietnamese.
Thank you very much!
But when I change to Vietnamese Language, “Vote” changes to “Đã Bình Chọn”, so the button can not cover the word. How can I fix it? (Can we make the size of button bigger to cover all words?)
In my opinion, you just need to adjust the CSS and it should be fine. Could you please share the website so everyone can help?
Hi. Can we just change location to VietNam ( to make url friendly) but keep the rest? I want to use English ( the original)
Unfortunately that’s not possible at the moment. You could create a feature request in the #feature category if you wish.
As an alternative you could change the value of the slug generation method site setting.
“encoded” would look like this:
Or you could disable the slug by setting it to “none”:
尊敬的 @cuongnguyen uong 师兄,不知截至当前,您是否已处理完此问题?
非常感谢 :heart:
