Is there a way for when a user uploads an mp4 or video it shows a player function and not just a link to download the video?
Not talking about sharing a one box link but a direct upload of an mp4.
Handling videos is a lot of work. You are better off using a dedicated video sharing service and linking to it.
Nothing that’s integrated with it? Or ideas on how to set it up? Some fight videos I want to host that streamable and sites with exception of live leak don’t delete automatically.
It already works this way, try uploading a short mp4 clip and it will work fine, as you can see here:
You’re simply going to run into upload limits because videos are HUUUUGE. Upload those clips somewhere that specializes in hosting video and then link to them, like everyone else does, which also provides a built in player .. ![]()
Given embedded options, isn’t it better to upload on video sharing site like youtube instead?
Doesn’t need to add extra layer of unnecessary censorship too…
-edit-
Plus it allows much bigger videos without storage strain ![]()
Thanks @codinghorror. I guess my older forum I stopped trying cause a few times just gave me links to download only. I’ll give it a shot today.
@OrcaFrost I wish but I was on a Reddit sub similar with what I wanted and about half of the top videos were deleted. I just hate when I click on links to watch a video and it’s gone. That’s what I was trying to prevent. I know Reddit subs started making mirror bots but sometimes those are deleted also and Reddit is so large the quality of what’s posted is bad.
I’d hate to cost more then I needed too especially for such a small site project but I really hate dead links if I can avoid it. And LiveLeak is a rabbit hole I just don’t want to go down linking back too lol
Worked perfectly! Thanks!
Can I tack a support request on to the end of this thread?
When I click the upload button here on Meta, and upload a MP4 video, it does not transform my link and leaves it as:
https://global.discourse-cdn.com/meta/original/3X/8/e/8e88d0b77c6b9eafff95c0c6c444aa2f6dba856c.mp4
And it embeds a player ![]()
However, on our Discourse v2.2.0.beta10 +16 when I upload a video it replaces the link and turns it in to an attachment of sorts:
<a class="attachment" href="//greyarrows.s3.dualstack.eu-west-2.amazonaws.com/original/2X/8/8e88d0b77c6b9eafff95c0c6c444aa2f6dba856c.mp4">20181207_M62_Vehicle_Fire.mp4</a> (2.9 MB)
I’m guessing this is a setting we have changed somewhere.
Question is, does anyone know how to undo / fix this?
To answer my own question, this setting was enabled:
prevent anons from downloading files
Unticking it then allows uploaded videos to be embedded with a video player.
سؤال سريع، هل من الممكن حاليًا إضافة سمة صورة ملصق للفيديو؟
(الخلفية: نود دعم الفيديوهات من ويكيميديا كومنز في نسختنا، لكن الفيديوهات غالبًا ما يكون لها إطار أول غير جذاب يظهر كمعاينة، لذا فإن إضافة صورة جميلة كصورة ملصق لوسم الفيديو ستكون تحسينًا رائعًا)
هل هذا الإعداد متاح للمشرفين أم للمدير فقط؟
جميع تعديلات إعدادات الموقع متاحة للمسؤولين فقط، وليس للمحررين.
شكرًا لك سام. كنت أعرف الإجابة قبل أن أسأل، لكنني أردت التأكد. LOL
مشكلتي تكمن في كوني مشرفًا مع وجود حدود، ومديرًا ينشغل بواجباته الأخرى، بالإضافة إلى عدم رغبتي في التعامل مع طلبات مزعجة مثل البحث في لوحة تحكم المسؤول وفهم كيفية القيام بأشياء بسيطة (مثل تغيير إعداد أو وظيفة، أو إنشاء فئة جديدة، إلخ) عندما لا تكون ضرورية. الأمر محبط أحيانًا.
شكرًا لك على التأكيد. ![]()
