Qual è la best practice per "pinning" i post in un argomento?
Often there will be a thread with 50+ posts about a newly-introduced bug on our platform and we want to let users know we are working on it. If we just add it as a normal post, it can quickly be drowned out by other replies. We can mark it as the “solution” to pin it to the OP, but this is hacking a feature to do something it wasn’t intended, and misleads users who see the solved checkmark into thinking the issue is resolved. We could alternatively edit the OP to something like:
Edit: This is being looked into by engineers
[quote]
but some users don’t like their posts being edited.
What is the ideal way to handle this?
3 Mi Piace
If users don’t have access to tagging themselves then why not have staff tag topics as acknowledged / investigation / resolved? Is it important that users see specific replies?
They have access to tagging, but even if not, tags are tucked away and hard to notice. And yes, contents of replies are important to see since they may contain information like expected resolution time, requests for more info, etc.
I can see some value to pinning posts within topics themselves. Until someone develops the equivalent of a blue post (staff post) plugin to highlight where staff posts are in the topic/timeline and then hop between them it’s useful to know where to look for official responses.
From personal experience people bookmark the threads directly, particularly when it comes to tracking issues and bugs. They may never revisit the parent category to see other topics.
It’s a hard behavior to crack, which is why we’re forced to consider stuff like edit the initial post or abusing the Solved plugin. Neither is a real solution, but I’m not sure one exists right now?
4 Mi Piace
Moving this to a #feature request as I’ve now had the same request from a customer.
Their use case is the same as the OP.
  • A bug or feature is being worked on
  • Staff updates are being lost in the noise (even with Staff Colour)
  • They are not comfortable editing the OP to include updates
  • They don’t want to mark something solved because it’s not
6 Mi Piace
I can see use case here and also see how it departs from “solved”
In particular you would allow multiple posts to be “featured” in the OP:
Jane "pm" 2 hours ago: We will be looking at this [v expand]
Jill "dev" 1 hour ago: I am working on a fix [v expand]
@codinghorror I wonder if this is core feature, aka “Pin post..” complete with “how long you want to pin it” or in the far to rare department and should be a discourse-pinned-posts plugin.
Personally it feels like a discourse-pinned-posts plugin to me, but it shares lots of DNA with discourse-solved so we would need to be careful about code duplication here.
6 Mi Piace
Not exactly, maybe solved needs an in-progress state that behaves almost the same way as solved but does not confer full solved-ness.
6 Mi Piace
Solved only works if it’s a unique post about an issue, or there’s a definitive endpoint.
It would be useful to move between staff/moderator responses in a topic regardless, or offer a tweaked summarize which includes them all.
One idea we came up with on my forum is to edit the topic title. Inelegant, but at least it will get the members’ attention.
I really like this idea – maybe “potential solution” or something like that? (In my ideal world, this would be a setting that could be enabled if an admin felt it appropriate with a little text box for the title of the “in progress” or “potential solution” or whatever.)
Sono molto curioso di sapere dove sia finita questa richiesta di #feature. È possibile ottenere questo risultato ora; se sì, dove posso trovare quella impostazione?
Se no, qualcuno ha nuovi suggerimenti diversi dal modificare l’OP o il titolo dell’argomento?
Potresti espandere un po’ e, se possibile, linkarci un argomento del tuo forum in cui vorresti utilizzare questo tipo di funzionalità.
Nel corso degli anni abbiamo apportato alcune modifiche: ora è possibile annotare i post, ma non esiste ancora un modo per evidenziare automaticamente più post nell’OP senza modificare direttamente l’OP.
Marzo 2019 @HAWK ha scritto “Sposto questo a una richiesta di funzionalità, dato che ho appena ricevuto la stessa richiesta da un cliente.” e stavo solo chiedendo se la possibilità di fissare un post all’interno di un argomento sia stata implementata come funzionalità in Discourse.
Uguale a questo @michellefs .. sembra che le persone vogliano un esplicito indicatore “non fatto, ma è in corso” per la “soluzione”.. come una “soluzione mezza fatta”, “soluzione un quarto fatta”, forse anche una barra di avanzamento se le persone vogliono una stima percentuale di “quanto è fatta” qualcosa?
Questo almeno farebbe sapere alle persone che la soluzione è in corso, rispetto al fatto che non ci si sta lavorando affatto.
Non sono sicuro di aver capito correttamente il titolo della discussione, ma ho utilizzato il “fissaggio dei commenti” principalmente in tre scenari (nella mia precedente azienda):
  1. per le migliori risposte, simili alla funzionalità “soluzione”, di solito abbiamo bisogno di fissare solo un commento.
  2. per le AMA della community, dove apriamo una discussione per domande e risposte su un argomento tra utenti e staff, di solito dobbiamo fissare almeno 30+ commenti per evidenziare le risposte dello staff, una volta ogni trimestre.
  3. per evidenziare ottimi UGC (foto, video, persino meme) nelle attività della community, ad esempio un thread fotografico mensile, di solito dobbiamo fissare almeno 10+ commenti.
spero questo aiuti :wink:
Non era con Discourse, vero?
Concordo sul fatto che sarebbe utile poter fissare un numero qualsiasi di risposte in fondo al primo post di un argomento (come collegamenti alla risposta effettiva, per evitare di incasinare il threading).
