عند التواجد في فئة، اضبط الافتراضي على "لا شيء" بدلاً من "الكل" للفئات الفرعية
I’d like to find a way to default the view for all users to display “none” rather than “all” subcategories, when in a category. “all” would be an option they could select. Is there any way to achieve this?
Generally, my community is finding “none” as an option to select unintuitive.
I think you are looking for the checkbox to limit display of subcategories within a category; this already exists.
No - that’s totally different. When you display subcategories it looks more like a categories page. I like the list of topics, but just want to see the list of topics for the category (none), not for the category plus subcategories (all).
Fixed it via JS. You have to add this code to your head.
// For categories list
$(document).on('mouseover', 'td.category div.pull-left a', function() {
    // do it only once
    if ($(this).hasClass('link-fixed')) {
        return;
    // do it only if there's subcategories
    if ($(this).parents('td.category').find('div.subcategories').length) {
        var link = $(this).prop('href');
        $(this).prop('href', link+'/none');
    $(this).addClass('link-fixed');
// For dropdowns
$(document).on('click', 'ol.category-breadcrumb li', function() {
    // do it only once
    if ($(this).hasClass('links-fixed')) {
        return;
    // do it only for first dropdown
    $(this).addClass('list-clicked');
    if (!$('ol.category-breadcrumb li').slice(0, 1).hasClass('list-clicked')) {
        $(this).removeClass('list-clicked');
        return;
    // you can't check subcategories from here, so doing it for all
    $(this).find('section.category-dropdown-menu div.cat a').each(function() {
        if (!$(this).hasClass('home')) {
    $(this).addClass('links-fixed');
// For breadcrumbs when reading a topic
$(document).on('mouseover', '.title-wrapper .ember-view a', function() {
    // do it only once
        return;
    // do it only for first button
    if (!$('.title-wrapper .ember-view a').slice(0, 1).hasClass('list-clicked')) {
        return;
I don’t think this will work on phones. There’s probably no such events as “mouseover”.
Wanted to say thanks for the JS fix Maestra, and make a small contribution:
The above JS works 99% of the time, but a user found that when they clicked on the little unread notification in the categories list, it took them to a page that doesn’t exist. E.g., for meta.discourse.org they’d end up here: https://meta.discourse.org/c/feature/l/unread/none.
The minor edit I used to fix this is to slap the following at the top of your first section of code for the categories list, right after the if: ‘link-fixed’ bit.
var ignore = /(unread|new|top)/
//ignore unread, new, top links
if(ignore.test(this.getAttribute('href'))){
    return;
The ‘top’ part might not be necessary in retrospect, but whatever it doesn’t hurt anything.
edit - I suppose more sophisticated regex might be in order if one of your categories has “new”, “unread”, or “top” in the name, though.
For me the first part for the category list did not work. so here is my solution.
 $(document).ready(function() {
        // do it only once
        $('td.category .ember-view a').each(function() {
                return;
Hi
I am having some issues with this… I added the js to my head section but apparently it breaks if you click on the logo to get back to the home page.
Step to reproduce:
  • go to the discourse website
  • select a category with subcategories → it works, defaults to “none”
  • click on the discourse logo (upper left) and go back to the home
  • select a category with subcategories → it doesn’t works, defaults to “all”
Any idea why ?
Is it so hard to make second’s dropdown list value configurable?
I’d love to see this as a built-in feature too.
We’re using subcategories for discussions in different languages (one for English, one for Spanish etc.) so seeing a list of discussions in different languages on the parent category page is a bit confusing for people.
It would be really useful to be able to have ‘None’ as the default view for the category page (as in screenshot below) instead of ‘all in [category name]’
None
Are there plans to implement this?
I just had to modify some code.
Just make this line execute uncoditionally.
Thanks Artur, glad you found a simple solution!
We’re on a hosted instance of Discourse, so unfortunately don’t have access to the source code. We’ll keep using the Javascript workarounds from above; they’re great, but we haven’t found a way to solve the issue described by Cataldo.
للأسف، الحل المقترح لا يعمل بالنسبة لنا. :frowning_face: نحن بانتظار الدالة المدمجة.
أليس هذا ممكنًا مع خيار الربط إلى القسم؟ للأسف، لم ينجح الأمر معي.
نعم، نود أيضًا أن تكون هذه خيارًا مدمجًا، مما سيجعلها تعمل بشكل يشبه المنتديات في الماضي.
فقط أتفقد لمعرفة ما إذا كان هذا لا يزال قيد النظر أم تم استبعاده تمامًا…
سيكون رائعًا الحصول على تحديث بشأن هذا، حيث سيجعل الحياة أسهل بكثير للأشخاص الذين ليست لديهم خبرة كافية في استخدام Discourse (المستخدمون الجدد في المنتديات).
هناك إعداد لهذا الغرض على أساس كل فئة على حدة.
انتقل إلى صفحة الفئة. على سبيل المثال…
https://meta.discourse.org/c/support/6
ثم انقر فوق أيقونة المفتاح هنا
category edit button
هذا سيأخذك إلى إعدادات تلك الفئة المحددة. من هناك، انقر هنا.
ثم قم بالتمرير للأسفل قليلاً حتى ترى هذا الإعداد
غيّر ذلك إلى “لا توجد فئات فرعية” كما هو موضح هنا
وهذا سيعطيك النتيجة المرجوة لتلك الفئة - قائمة المواضيع لتلك الفئة ستعرض فقط المواضيع في الفئة الأصلية وتتجاهل المواضيع في الفئات الفرعية.
إذا أردت أن تظهر صفحات الفئات الأخرى نفس السلوك، فكرر العملية لتلك الفئات. كما ذكرت أعلاه، هذا إعداد خاص بكل فئة على حدة.
شكراً على هذا الحل. هل هناك طريقة لرؤية عرض “الكل” أو عرض “لا شيء” بشكل مستقل عن الإعداد؟ حاليًا، يتعين عليّ تعديل عنوان URL وإضافة “/none” وهو غير متاح للشخص العادي.
تحرير: نعم، يوجد، أنا آسف!
