[aiuto] multisito con letsencrypt-nginx-proxy-companion
In my app.yml, make these changes:
Only expose port 80:
expose:
- "80"   # fwd host port 80   to container port 80 (http)
In the env: section, add the latter 3 new lines:
  DISCOURSE_HOSTNAME: 'a.com'
  VIRTUAL_HOST: 'a.com'
  LETSENCRYPT_HOST: 'a.com'
  LETSENCRYPT_EMAIL: a@a.com'
Then run ./launer rebuild app
and my docker-compose.yml looks:
version: '2'
services:
  nginx:
    image: nginx
    volumes:
      - "./etc/nginx/conf.d/:/etc/nginx/conf.d/"
    environment:
      VIRTUAL_HOST: a.com
      LETSENCRYPT_HOST: a.com
  nginx-proxy:
    image: jwilder/nginx-proxy
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - "./nginx/vhost.d:/etc/nginx/vhost.d"
      - "./nginx/html:/usr/share/nginx/html"
      - "./nginx/certs:/etc/nginx/certs"
      - "/var/run/docker.sock:/tmp/docker.sock:ro"
  letsencrypt-nginx-proxy-companion:
    image: jrcs/letsencrypt-nginx-proxy-companion
    volumes:
      - "/var/run/docker.sock:/var/run/docker.sock:ro"
    volumes_from:
      - "nginx-proxy"
Then i run docker-compose up,when i visit a.com,i got 502.
Waitting for help
It looks like you messed up the very sensitive yml file (i.e. used tabs instead of spaces to indent)
Try testing it with a linter
thanks first,and it shows: Valid YAML
In that case it might be something to do with your multisite setup.
I just noticed this:
that is a “ch” typo, correct?
I guess the next question is what guide(s) did you follow?
:grinning: i can visit it use http://ip:port,but when i get 502 with https://ip:port
